2022-02-09 07:08 PM
It would be great if at the point of application of a generated door favourite, the user could select if some of the existing door properties could be retained...for example the assigned fire rating. In a similar fashion to how you are able to keep the same door width. Many Thanks!
2022-02-10 02:37 AM
That is interesting.
The favourite saves the classification and property values.
But the classification & property values are not applied when the favourite is used.
Even though in 'Element Transfer Settings', 'Classification & Custom Properties' is ticked.
