2004-05-08 06:16 PM
2004-05-08 08:33 PM
Geoff wrote:.. right double click to get object information ...
The common computer task of double clicking does nothing in ArchiCAD. This is a wasted opportunity. I suggest it be assigned to a particular task depending on the object. For example double click on a text or label object and immediately get the text cursor. Double click a section or detail marker to open the corresponding window. What do you think?
2004-05-10 10:36 AM
2004-05-10 01:18 PM
laszlonagy wrote:This is probably the best way to go. The default should be to open the settings dialog. This would be consistent with most other programs.
Why not have the ability to assign to double-click a specific task performed by ArchiCAD, so this could be customizable as well?
Laszlo
2004-05-10 07:33 PM
Matthew wrote:Nope, Matthew, this is alredy item 1 on the context menu, therefore only two clicks away. The list of assignable actions should be everything that is NOT on the context menu - oh, BTW, that one should be customizable, too (speaking about other programs)laszlonagy wrote:This is probably the best way to go. The default should be to open the settings dialog. This would be consistent with most other programs.
Laszlo
2004-05-10 08:26 PM
2004-05-10 10:47 PM
2004-05-10 11:16 PM
bill wrote:I assume you are using a Mac with an Apple mouse.
what's a right click?
bill
agonisingwhether to get a third party (washes mouth out with soap) multi-button thing
2004-05-11 01:13 AM
Djordje wrote:I don't agree. The best use for the DC may be something that's already in the context menu. The Open Section/Elevation command is in the menu but would be my choice for DC. Fully custimizable is best.
BTW, that one should be customizable, too (speaking about other programs)Abosolutely.
2004-05-11 09:07 AM
