2009-04-18 01:52 AM
2009-04-18 01:15 PM
Dragan wrote:I'm not sure if I understand you correctly. However, I have no problems adjusting height (z-position) of either a complete Archicad standard mesh, or of its individual nodes, using Archicad standard tools (pet palette).
...and it won't be solid until you change thickness to 20m minimum.
There is no way to change Z-value of the points respectively, if you try it with Heigh tool you only change elevation of mesh. That is problem with Archi Terra add-on....
2009-04-18 02:25 PM
2009-04-19 10:15 AM
2009-04-19 11:48 AM
Properties: A 61.2309001147 B 110.7232338862 ZZYZX 30.20300674782 3D script: mulx A/61.2309001147 muly B/110.7232338862 mulz ZZYZX/30.20300674782 add 23.06002637192, 27.68080846121, 13.2238436898 body -1 model solid resol 36 addz 5 mass "LS-Grass Green", "LS-Earth", "LS-Earth", 32, 93, 21, -15, 38.17087374278, -27.68080846121, -12.06940269391, 15, 38.17087374278, -13.84040422544, -10.16132979842, 13, 38.17087374278, 1.033666185979E-008, -6.261257302278, 13, 38.17087374278, 13.84040424611, -3.585722246453, 13, 38.17087374278, 27.65755486279, -0.8128156450423, 13, 38.17087374278, 27.68080848188, -1.04698137561, 13, 38.17087374278, 41.52121271765, 1.365209804546, 13, 38.17087374278, 55.36161695342, 3.660084674067, 13, 38.17087374278, 69.2020211892, 5.846001653, 13, 38.17087374278, 83.04242542497, 13.74015427248, 15, 22.8631487141, 83.04242542497, 12.63193233422, 13, 7.555423685427, 83.04242542497, 15.14256049167, 13 etc...
Properties: A 61.2309001147 B 110.7232338862 ZZYZX 30.20300674782 3D script: mulx A/61.2309001147 muly B/110.7232338862 mulz ZZYZX/30.20300674782 add 23.06002637192, 27.68080846121, 13.2238436898 body -1 model solid resol 36 addz 3.284408079443 mass "LS-Grass Green", "LS-Earth", "LS-Earth", 32, 93, 21, -13.28440807944, 38.17087374278, -27.68080846121, -12.06940269391, 15, 38.17087374278, -13.84040422544, -10.16132979842, 13, 38.17087374278, 1.033666185979E-008, -6.261257302278, 13, 38.17087374278, 13.84040424611, -3.585722246453, 13, 38.17087374278, 27.65755486279, -0.8128156450423, 13, 38.17087374278, 27.68080848188, -1.04698137561, 13, 38.17087374278, 41.52121271765, 1.365209804546, 13, 38.17087374278, 55.36161695342, 3.660084674067, 13, 38.17087374278, 69.2020211892, 5.846001653, 13, 38.17087374278, 83.04242542497, 13.74015427248, 15, 22.8631487141, 83.04242542497, 12.63193233422, 13, 7.555423685427, 83.04242542497, 15.14256049167, 13,Meshes were exported with AC standard tool 'Save selection as'. It was expected that the Z-values in mass were changed/reduced by 1.7256, but changes were only in relative movement and h-value of mesh, witch actually means only changes of b, t, Elevation and Mesh Height of the object.
2009-04-21 03:05 PM
Soubroutine SvitchHeight() ! user wants to change height - clicked on mesh point - selected 'Switch Height' tool Pick up deltaZ foreach z-value in MeshPoints Z-values corect Z-value for deltaZ next ! don't change Elevation or Mesh Height end ! redraw changed objectIt can't be done through GDL, but only on low level because GDL can't see point values as up to my knowledge
2009-04-21 03:55 PM
Dragan wrote:Yes, thank you. Now I finally understand that you want to move the upper (or lower) surface of the mesh, relative to the other, so the overall thickness increases - what a Stretch Height tool should do.
...Can you catch my meaning now
2009-04-21 06:00 PM
Thomas wrote:Sorry, but I still think that You missing my point
And now that I've tested it, thats exactly what it does:That is exactly what I did in my last example. You can see the result in exported mesh.
1 - select mesh
2 - click mesh tool (main palette)
3 - click stretch height in the pet palette
4 - drag a node on the upper or lower surface.
2009-04-21 07:38 PM
2009-04-21 10:01 PM
