Wishes
Elements placed on unseen stories
gpowless
When placing objects, walls, etc where their home storey is not the current storey an 'Information' dialog pops up warning
"As the result of the last operation, Elements have been
created and/or changed their position on currently
unseen stories."
UNDO CONTINUE
Instead it would be better to have the options
Change to Storey Level: (current storey, [other stories])
Show on Storey: (current storey, [other stories])
Continue
Cancel
The process of selecting undo, closing the dialog, opening the Element dialog, adjusting the home storey, adjusting the view on stories and starting the Element (especially when you have just drawn a chain of 10 walls) process again is frustrating.
Please revise this dialog and process to streamline the process.
Please vote. Thanks
Intel i7-6700@3.4GHz 16g
Definitely agree that this is very annoying and should be changed as suggested.
gpowless
Support is needed.
Hmooslechner
Continue
Cancel
and also
determine possibe visibility-options - if the element should be inserted in the set way.
even if its not visible - there should be a simple way to edit this item later.
