Dimension Text Needs More Autotext Options
Dimension text content currently only allows you to add measured values and superscripts to your dimensions. The Autotext function for dimensions could be enhanced if other Autotext options were added. For example, Element ID could be added to the Autotext options for dimension text, allowing you to add IDs to the dimension text for dimensioned elements such as doors and windows. This would be very convenient in situations where Element IDs may have been altered, requiring dimensions with custom text to be updated to correlate with the changes made.
