Hi Gyuri:
The contractors (and sub-contractors) I work with are slow to adopt a
paperless work environment. They require printed docs.
(maybe this will change if someone develops a tablet with a A1 screen size
I share the BimX model from the transfer site and email a multipage PDF, with
the exact same set of 2D drawings. They either print the PDF's in house
or send to a Print Service. AirPrinting a multi-page PDF directly from
BimX is a tedious process.
Every update to the BimX file requires another PDF set to the contractor.
Having PDF's files of each revision is a must to document/track changes.
The ability to send the 2D drawings from the BimX file streamlines the process.
Perhaps this is a moot point if the desktop version had the functionality
to view (and print) 2D documents.
Hope you're staying safe & healthy
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 48 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8GB
ArchiCAD 25 (5010 USA Full)
