2012-06-06 05:56 PM
2012-06-06 11:23 PM
2012-06-12 04:28 PM
2012-06-12 10:05 PM
zach wrote:PLN, RVT and formats for Allplan, Telka and so on will most likely always be closed and proprietary. There is negative incentive to the publishers, the technical issues may be insuperable and it's unlikely that they could be shared well enough to be useful. DWG was a special case and it's use as a common format was long opposed by Autodesk.
I mostly blame autodesk for this, there is DWG import/export in ArchiCAD but no PLN options in Autocad
2013-01-14 01:22 PM
2018-08-02 05:35 PM
2018-08-16 09:45 PM
2018-08-18 05:25 PM
2018-08-20 02:44 PM
LaszloNagy wrote:I don't have Twinmotion, but I had it for a short while as trial. I did install the export plugin a time ago for AC21 and later I unistalled it. Also I didn't install it for AC22..... and at the moment I have the FBX export option it on AC21 and AC22.
This FBX export option is not available in ARCHICAD by default.
I think it is installed as part of the Twinmotion Add-On so it is only available when you have Twinmotion installed.
2018-08-21 01:22 PM
Strange. This would mean that after installing Twinmotion trial you get permanently the FBX export option in AC on all your Archicads.
Anyway its there and works great.
https://twinmotion.abvent.com/en/twinmotion-dynamic-link-for-archicad/
