2004-10-18 06:07 AM
2004-10-18 02:57 PM
James wrote:Oreuplulos and James
I think that the whole favourites thing needs to be replaced with sytles (like in InDesign). I tried out the favs thing but never really used it - didn't really seem to save time when you can easily pick up and inject properties from one object to another anyway - a feature which I love.
2004-10-18 03:49 PM
Jay wrote:It simple.
What do you mean styles? Like in InDesign if you change a style, all the objects made with that style will change automatically? This means, that I don't have to redefine all the time the walls, just once, and than just refine them?
How many styles will I have to make so?
2004-10-18 04:56 PM
2004-10-18 07:37 PM
Link wrote:It could be implemented in various ways,
theymaycreate a strain on the program.
2004-10-18 08:01 PM
Jay wrote:Composites provide a hint (and only a hint) of what styles could do for production. In a given project, for example, define a composite for each 'type' of exterior and interior wall and define those walls with the corresponding composite. Note: a composite need not have more than one skin! A one-skin composite is sort of a style.
2004-10-18 08:54 PM
2004-10-19 02:07 PM
oreopoulos wrote:I was thinking about how much would this be timesaver for me. Forexample I used to have 6-8 kind of walls in a project, so that would be usefull. But the text blocks I never counted, I just refine them when placing.
For example dimentions. You can create 3-4 differnet styles- favorites
and change according to what you want. From text height to metric system to ... And you can just change style this to style that. Powerfull i guess
2004-10-19 03:18 PM
Jay wrote:As i wrote in my mind the implementation is adding a variable-parameter to each object witch links it to a favorite.
And the other thing is when you want to change just one wall, but not all of them, wich was made with the same style/fav. All of them will change or just that one, and itt will loose the favorite feature?
2004-10-21 05:26 PM
As i wrote in my mind the implementation is adding a variable-parameter to each object witch links it to a favorite.This sounds very similar to an idea I posted quite some time ago:
