Hi Jeff,
The translators are stored in a non-version-specific folder on your hard disk. For me (Mac) they are here:
Macintosh HD:Users:karl:Library:Application Support:Graphisoft:DXF-DWG Translators
Check the 'Location' field of the DXF-DWF Translation Setup dialog to see where your are stored. Examine the date/time stamp on the ones that seem incorrect to you.
The default US 12 installation does not have the text issue you raise. (It actually did - again! - in beta, but was fixed prior to release.)
It is possible that you are seeing this (Dutch) text problem because the 'bad' translators were installed for some earlier version and have never been deleted or edited. (One could argue that each version should have its own folder of settings, which would also avoid this carryover problem - but then it would be an extra step to find old, useful translators and bring them into the new version.)
HTH,
One of the forum moderators • AC 26 USA and earlier • MacOS 11.6.8, iMac Pro
