Wishes forum
Fill number - Standard and locked
When writing GDL objects, I often use Solid fill and Empty Field. From one file to another, the ref. n° of the fill is changed so you can't use the n° to define the fill type, but you can't use the name neither as it seems to change in each version, and the std fills Solid and Empty are not called the same in different langage version.
I really wish Fill N°0 = "Empty fill" and Fill N°1="Solid fill" in every file created in every version...
2 REPLIES 2
Fabrizio Diodati
Wow!!!
Someone asking what I looked for the last five years...
I want to re-write what you just asked in another wishes post:
"MAY I POST 100.000.000.000 vote for this wish?
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy |
phone: +39 041 8943500 | Skype: fabrizio.diodati |
email: fdiodati@graphisoft.com
Miquel Garcia
Absolutely agree ! But we need a method to manage the ID number of the fills in order to recover old files and objects. If Attribute Manager was able to directly edit the ID of the attributes it will be a help.
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
