2015-05-11 11:39 AM
2015-05-11 12:59 PM
2015-05-11 02:01 PM
laszlonagy wrote:No Laszlo, I usually operate exactly as you say. It's just that being able to just toggle the invert selection would speed things up, specially with loaded models...
The way to do this is to select everything and then subtract elements meeting your criteria using the Minus button of the Find and Select Palette.
Or am I misunderstanding what you are trying to achieve?
2015-05-11 04:23 PM
2015-05-11 05:01 PM
Barry wrote:Well, the point of having the inverse selection toggle is to do only one database search, which makes a difference with big models, I guess...
CTRL+A (select all) then Find & Select and subtract criteria compared to Find & Select, add criteria and then toggle shortcut (if it was available).
I would say this would take about the same time and steps to do.
2015-05-12 04:02 AM
2015-05-19 05:39 AM
2015-05-19 05:47 AM
methy wrote:No, that can toggle the visibility and locked status of layers but not toggle the selected elements themselves.
I may not be understanding exactly what you require but could this be done with the quick layers palette?
2015-11-28 03:07 PM
2015-11-28 03:39 PM
