2022-08-01 10:04 AM
The F&S - Positioning options should include "Home Story" to help find displaced elements that are at the correct height but assigned to the wrong story or appearing in the wrong view.
2022-08-01 12:15 PM
I believe F&S should have same options as schedules, especially Library Part Parameters.
2022-08-02 04:03 PM
Hello DGSketcher
Yes, I agree. But there is a workaround, if I understood correctly what you need:
Add an Archicad property expression, where you put the "Home Story" name or number. You can then use this property in the "find & select" dialogue!
Jonas
2022-08-02 04:27 PM
@Jonas Krieg Thanks for the suggestion. There's another way which is to assign a GO to highlight things on a story, but I was troubled trying to find an elusive 2D object on plan which doesn't always highlight as well as 3D.
