2014-03-20 03:40 PM
2014-03-20 04:06 PM
another Moderator
2014-03-21 08:15 AM
ejrolon wrote:- I really would need to be able to select the windows in the façade with Find&select tool. The situation is this: in plan all the windows are numbered with consecutive numbers that includes the level index,but in the façade i need the number of the type of window..The project has 3 blocks, each one of then has 4 levels..and (as I know) you can only label a window when it is selected it in the façade and not in 3D..
1. Find and Select work in Sections and Facades though sometimes it is easier to select them in 3D since you can select all the pertaining windows while in S+E you can only select what is visible.
2. Which criteria are you missing? There are a lot of parameters that you can choose from…
2014-03-21 10:18 PM
another Moderator
2014-03-21 10:37 PM
