Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Find & Select w/Wall Composites
I searched for this wish, but found nothing, so here it is...
In the Find & Select dialog I would like to see "Wall Composite" as one of the filter options. I can use this is two situations. First, I could select all instances of walls with one composite and change them to another composite. Also, we use the ID field to indicate the wall type, so I could select all walls of a particular composite and make sure they have the correct wall type callout.
4 REPLIES 4
its there !
find and select -> element = wall -> choice = fill
and in the fill popup you select the composite you are searching for
Holy #$@%! Why is this called "Fill"? I could have been using the freakin' thing, but I thought it was for specifying a fill, since it's named "Fill". AARRGGG!!!
Rob
Jay, your wish came true in one day!
That's what I call efficiency
::rk
Because composites are not true, virtual, laminated walls ... they are faked with a 2D fill.
Or, perhaps the choice of composite wall (fixed width and fill as in composite settings) or standard wall (adjustable width, single fill) is made via the fill parameter of the Wall tool?
Or...
One of the forum moderators
