Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Find & select static dimension
Hi Graphisoft
Please, can you develop tool to find & select static dimension(s) (or static part of semi dynamic dimension chain)?
Quit often teamwork members copy and paste dimension in different ways from one workspace/file to another and in some cases dimension (or part of the dimension chain) becomes static.
It is really annoying and time consuming process to find out the static dimension in large projects to replace with dynamic ones (recommended to avoid mistakes).
Thanks in advance
Hope to hear positive reply
Cheers
Z
VERY TRUE!
And not only static Dimension Chains, but those Dimension Points within a Dimension Chain that are static.
