Wishes
Fix Top-View of inclined Wall-Connections
snow
Ace
Hello together,
the option t tilt wall is already long time onboard...
Just I realized that the top-view of connection with vertical walls is wrong.
In 3D everything o.k.:
... but in the floor plan, we get this:
So please could you fix that, this way:
ARCHICAD for Future
archicad versions 8-27 | mac os 13 | win 10
12 REPLIES 12
That is odd.
When I try in 25 it seems to work just fine.
snow
Ace
You've a cut view, not the top view – right?
ARCHICAD for Future
I was just showing the 3D view and the floor plan (which you said was wrong?).
snow
Ace
Only 😁 the top-view in the floor plan is wrong...
... from time to time we need such view...
ARCHICAD for Future
What do you mean by the 'top view in floor plan' ?
The floor plan is a top view.
Are you using 3D Documents?
snow
Ace
Is it really so hard to understand what I mean?
Do I maybe use the wrong expressions... because English is not my mother tongue?
Could somebody help here?
ARCHICAD for Future
Language can be a problem.
You mentioned a 'top view' of the walls - I am unclear what you mean by this.
Then when you show the image you mention "in the floor plan we get this".
In the floor plan I have no problems - it appears to me as you said you wanted it.
Here are 2 inclined walls and 2 vertical walls.
All the same heights and shown with 'Projected' floor plan display.
If this is not what you are seeing, then the challenge is going to be making sure we are both talking about the same thing.
snow
Ace
Just have a German version available right now...
Writing about these expressions...
ARCHICAD for Future
Yes I believe we are looking at the same things.
Is it anything to do with your Floor Plan Cut Plane settings?
