Wishes
Fix the stacking order!
Geoff Briggs
Mentor
I know this issue has been raised a hundred times before. I don't care. After dropping four large on software I should never, ever, ever see a warning like this. It's a 3D model for pete's sake. Things are on top of each other! It's criminal how much time I spend shuffling things forward and back. When I see this dialog I just want to scream.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-27, M1 Mac, OS 14.x
5 REPLIES 5
Aussie John
agreed. Also I hate when you edit a element back in the stack and it then jumps to the front.
Cheers John
[/size]
Tom Krowka
Everything should have a stack number available in the info box so you can select each item and assign it a stack number. This will eliminate selecting items and pulling forward and pushing backward blindly, hoping something will look right.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Totally agree with all of you!
Tom's idea is a really simple solution to really annoing issue.
__archiben
sorry tom, but no no no!
we don't need any more controls and settings for elements than we already have . . . and that's currently too much!
far better for an intelligent automatic solution to this problem with manual override for times of crisis: consider this:
http://archicad-talk.graphisoft.com/viewtopic.php?p=78293#78293
... maybe?
~/archiben
b e n f r o s t
Tom Krowka
Cut plane manipulation is too cofusing.....I get too many unintended and unwanted results that one must go back and change. You are correct in the fact that while all the controls give great choices, it does take time. So I fifure what's one more control. It would take less time to change a default setting in the info bx than it would to click stack order back or forward over and over.
Maybe the compromise would be to show the present stack number in a dialogue box in the stack order command rather than move back one or move to the back, etc.
Thomas@wkarchwk.com
www.walshkrowka.com
