2004-02-12 04:46 PM
2004-02-12 07:42 PM
Brad wrote:First no - as that is the interaction of the building elements, especially if you use SEOs, and helps the working. Your wish would mean manual adjustment.
Does anyone else think that we ought to be able to manipulate walls more easily in AC? In the 3D view, for instance, grabbing a top of the wall and pulling it down to create a rake. This avoids a SEO and a hidden layer with a roof cutting object. VectorWorks has this, so I can't imagine it's too difficult.
This holds true, too, for making "battered walls": thicker at the bottom than at the top. As is, the add-on for this is awkward.
Brad wrote:Hmmmm ... don't think it is possible as of now; also think it might be dangerous and make the model overly complicated (as if it is not already ...)
Maybe the easiest way is to allow 3D objects to become walls (again, as in Vectorworks)?
2022-06-19 09:24 AM
I totally agree. Not be able to easy manipulate walls is so 2010
