2004-04-20 01:44 PM
2004-04-20 02:42 PM
2004-04-20 03:27 PM
Vitruvius wrote:What I'm really missing is another parameter : show in dashed lines the trace of the elements above the cutplane.
I would like to see this command modified such that the top view
PROJECT2 3,270,2, [cut section through object at this height]
2004-04-20 05:33 PM
Geoffroy wrote:This would be great. It could be accomplished simply by allowing the 2D script to define the line type to be used to draw the 3D projection. This shouldn't be too difficult since there is now the possibility to define a fill for it.
2004-04-20 08:43 PM
Matthew wrote:Hm, yes ...
This already exists.
2004-04-21 09:20 AM
Matthew wrote:The problem if we use the workaround of cuting once above, once below, is that AC would have to do two 3D projections to get the resulting image (the one drawn in plain lines, and the one drawn in dashed lines)...
2018-10-15 05:51 AM
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2018-10-22 10:14 AM
2018-10-23 10:50 AM
2019-02-05 01:57 PM
dkovacs wrote:Great tip! thanks!
Hello Everyone,
Actually, that already exists! PROJECT2 has 4 versions by now ( PROJECT2 - PROJECT2{4} ), each a little more enhanced than the other. The latest version, PROJECT2{4} is specifically designed to give the user control over cutting planes and different displays between them. Of course this can be used with a single horizontal cutting plane, and a different display setting above and below this plane (and of course the cut surface).
Here's a guide for how to use it:
http://gdl.graphisoft.com/tips-and-tricks/using-project24-command
If you just set one cut plane to any height, and then set the masks and modifiers to display things below visible, and above with hidden lines (wireframe), then it gets the job done. At first it might seem a little complicated, but you only have to set it up once, and you can just copy it to any of your objects. With the right globals and requests you can also set it to be aware of cut plane and story height!
Regards,
