I would like to see this command modified such that the top view
PROJECT2 3,270,2, [cut section through object at this height]
had an additional parameter to chop it off at a predetermined height above its origin. Think of it, no more goofing around with the 2D symbol scripting if you want to produce a really fast and simple GDL object. I waste so much time in virtually duplicate work making a parametric 2D representation match the 3D parametrics.
It could be used for doors, windows, and any special construction element which you'd like to truncate at 1200mm (or wherever) for the plan representation.
Cameron Hestler, Architect
AC 24 & 25 (3011) / MacMini i7-8700B @ 3.2 GHz / 32GB Ram / 512GB SSD
LG Ultrafine 4K monitor 22" & 27”
Mac OS 11.6 Big Sur
