As mentioned here ....
https://archicad-talk.graphisoft.com/viewtopic.php?p=314295#p314295
What if I need these values to be saved in an array ???
I would expect that your answer is "Then use an Integer Array Parameter", but based on the circumstances I have mentioned before, including those users that aren't versatile in GDL scripting, and maintaining library part's scheme & structure with Graphisoft's GDL styling, it breaks the object's programming scheme, luckily it only affected one portion, but if it was something else it would have caused a big mess
