Welcome to ARCHICAD Talk. Wishes generally focus on 1 specific item in order to allow Graphisoft to prioritize feedback. A smorgasbord like this is a great way to vent, but not to improve things.
When you post or ask questions, please search first. Pretty much everything you've complained about has been wished for already and so votes should go to those places. But, for what its worth, I don't anticipate Graphisoft giving us much in the way of GDL improvements any time soon - as nothing has been done with the language and environment for 17 years or so other than some additional commands.
Many things that you ask for have been desired for years by serious GDL programmers who are experienced in modern systems.
Many things you are asking for show that you do not understand what GDL is and does relative to API programming for ARCHICAD.
GDL is NOT a BIM coding language at all. It is NOT a scripting language for ARCHICAD. It is "Geometric Description Language" and allows for the construction of parametric objects (which happen to be data containers as well). Objects have zero knowledge of any other objects or the environment. That never was part of the design goals of GDL and I doubt we'll ever see that.
I'm not sure what you mean by "tools development" - but assume you mean BIM related tools, extending ARCHICAD. That's not possible with GDL. You can use GDL to produce a parametric object 'tool' such as Cadimage Windows/Doors, or to produce objects that read values from a file that define what the object looks like, etc. But that's about all. GDL is in essence, and intentionally, 'sandboxed'.
To develop tools, particularly BIM tools, for ARCHICAD, you must program in C/C++ using the ARCHICAD API which provides access to most of the internal data structures and classes. The things you complain about and want to do are all possible there, not GDL. Apply for developer access to the API site:
http://archicadapi.graphisoft.com/start
Content there is only readable by registered developers. It's a little odd...you have to sign in with a Graphisoft ID for even the 'register online' link to work. You should already have an ID from the myarchicad.com or other GS web site. Otherwise, create one.
If you become a developer, the Developer forum here is the chat area for the API and tools development:
http://archicad-talk.graphisoft.com/viewforum.php?f=23
One of the forum moderators • AC 26 USA and earlier • macOS Ventura 13.2, iMac Pro 10-Core, Radeon Pro Vega 64
