Wishes forum
Global Story Elevation Parameters
daviddelven
We need the Global Z coordinate value per each of the stories, in order to use them in expressions for QA tasks and many others.
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
7 REPLIES 7
Could you elaborate on this?
What do you mean by Global Z coordinate?
Nader Belal
Mentor
I would like to ask to add the this property as a Global parameter that can be accessed by GDL
Do you mean this?
Nader Belal
Mentor
@Braza
Something similar.
IE: It doesn't have to be the current story
The screenshot is from actual GDL reference manual. The parameter is already there.
daviddelven
We need to access this parameter from the Property Manager and the Expression tool.
I give you an example of some workaround we need to do because of the lack of this:
Did you check if any of these do the trick?
