Wishes
Graphic Override: Fill Orientation Option
The ability to specify the fill orientation within the Graphic Override.
Details are descripted here:
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=58017
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=73947
A suggestion for implementation could be like this:
22 REPLIES 22
Agreed.
Paul King
Another use case where fill origin and orientation control (or even just ability to remain the same!) through graphic overrides is needed is for cover fills to slabs, applied whether as vector fill associated with surface texture 'fills from surface', or as selected fills.
I have a case where a graphic override is needed in some views to change solid tile joint lines  to dashed tile joint lines in the cover fill.
When a graphic override fill is applied, the fill origin is just ignored , whether the original cover fill origin was set by surface texture origin, or manually
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
@Podolsky wrote:
It can be done automatically. Just if original fill set to fit the skin, then overrides do the same. Also following original fill origin and proportion.
Unfortunately this does not work for floor slabs - slab cover fills ignore texture origin, and fill cover graphic override ignore both texture origin and cover fill origin.
Also even without using slab cover fill, the vectoral hatching fill origin of a surface material applied to slab is also not respected by graphic override fill
Learn and get certified!
