Wishes
Graphic Override Skin & Cut Pens
DGSketcher
Legend
When I turn off skins with a solid colour fill override I end up with white lines in the published image. If we could assign a different pen colour to the skin lines then if required they can match the solid fill or display with a lighter pen than the element outline.
The Section Settings provide the ability to apply different pens to cut and uncut lines. If we could transfer this into the GO's with priority given to the skin pen selection where applied then it would simplify the section / elevation settings and allow for a uniform application of a GO to all views where cuts occur.
These relatively minor changes could lead to the phasing out of multiple pen sets and eradicate that nightmare of chasing down pen overrides that have been applied to individual elements...
0 REPLIES 0
