Wishes forum
Graphic Overrides and Graphic Override Combinations Import and Replace
Lee Hankins
Mentor
When updating Graphic Override Rules as part of Combinations in a Template, can it be made possible to then import the combination in to other existing files and have the option to replace the Graphic Override Rules which have been updated as part of the combination or append them and have the newly imported combination use the newly amended rules. At present if the updated and imported GO Combination uses a GO Rule that existing in the file, the Rule is not updated. You have to delete the existing Rule so when importing the Combination, the updated Rule is also imported.
Lee Hankins
ArchiCAD 4.5 - Archicad 26UKI Apple Silicon 4032
macOS Ventura (13.1)
1 REPLY 1
Benjamin Dani
Thank you for sharing your idea!
I'm glad to say that we took notice and we have added this wish into our Wish list database.
(For future reference, you can refer to it as IDEA-12337)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Dani Benjamin
Technical Support Engineer
