2003-12-11 03:00 PM
2004-01-16 12:53 PM
Ben wrote:Have you looked at the poll results? Fourteen votes:Essential - 6, Important - 5, Average - 3, with no votes for not important or not needed. Its seems to me everyone wants better looking drawings. Especially when you look at the number of improvements mentioned.
Yes back-lining is the reason hand drawn plans have so much more style. I would love to see it implemented in archicad but judging from the poll, no one seems to care
2004-01-17 07:41 AM
2004-01-17 10:52 AM
2004-02-03 07:09 PM
2004-10-27 08:12 AM
Philippe wrote:with archiCAD 9 comes the display option for having cut elements show with true weight and everything else hairline. there is a logical step here toward the introduction of back-lining: any cut element has an 'inside' and an 'outside'. archiCAD should have no trouble identifying this from a fill pattern (even if it's simply 'empty').
... I know that the principal difficulty is that it is necessary to introduce a direction with the lines so that the program knows where to "slip" the thickness but I cannot imagine to set that line by line...
2004-10-28 07:10 PM
2004-10-29 06:32 AM
Geoff wrote:essential
May I add my line improvement wish. That dashes share a common origin so superimposed dashed lines of the same type look like a single dashed line instead of a longer dash or solid line.
I'd like to use roof objects, displayed one story down, to show the line of roof above with a dashed line. But ridges and valleys appear as solid lines. Thus this little inconsistency forces additional drafting and coordination.
2004-10-29 08:17 AM
Geoff wrote:I'd like roofs to show as simply a dashed outline on the story below--with NO valleys or ridges.
2005-06-15 03:39 AM
2005-06-15 04:15 AM
