Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Graphics Override Components
insideru
I wish we could GO components of elements. I create many QA GOs, to be able to check different quality standards are met. Sometimes it would be really useful if i could GO components from Composites or Complex profiles, to check for continuity and proper building material assignment.
Example: GO all elements to white material, all wall insulation to red and all waterproofing to blue, then just make some marquees and visually check for continuity.
ARCHICAD 27 INT
macOS Sonoma
Lingwisyer
Guru
Please use the search function before creating new posts, there are a lot of wishes for this. That is one thing that has improved with the new forum... which will get even better once more posts have labels. Here are just a few;
https://community.graphisoft.com/t5/Wishes-forum/Graphic-Override-for-skin-types/m-p/242336
https://community.graphisoft.com/t5/Wishes-forum/More-amp-better-GRAPHIC-OVERRIDE-options/m-p/244157
https://community.graphisoft.com/t5/Wishes-forum/Graphic-Overrides-for-individual-parts-of-complex-p...
https://community.graphisoft.com/t5/Wishes-forum/Better-controls-for-Graphic-Overrides-for-replacing...
Ling.
Win10 | R5 2600 | 16GB | GTX1660
insideru
Thanks for pointing this out.
The new forums are a bit of a headache for me, but i promise i will learn how to use them 🙂
ARCHICAD 27 INT
macOS Sonoma
