Wishes
Grid line Marker Heads Change Scale With Drawing Scale
It would be really useful if the marker heads on gridlines would change size to suit the drawing scale.
We have a standard marker head size which is correct for 1:50 scale drawings. If you blow the scale up to 1:500, the marker heads become enormous in relation to the drawing.
The only work around I have been advised is to create a set of gridlines for each scale and define the parameters to suit.
This means you end up with multiple grids and therefore a high potential for errors to creep in.
You can do this with normal text, so why isn't this an option for marker heads??
If anyone does know how to do this can you let me know. Graphisoft support have told me it can't be done.
Tom.
1 REPLY 1
ryejuan
I have also encountered this problem with the Grid line when it comes to scaling. Has anyone resolve this issue?
Thank you in advance.
In the end what is your Objective?
ArchiCAD 9 onwards
