Wishes
Grids : Create, edit and drag-a-copy in section and elevation
Johann_P
Concerning grids:
It would be good if you could create, edit and drag-a-copy in section and elevation.
The limitation currently (version 24) is that grids are only visible in elevation and section, and can only be edited, created etc in plan.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
@Johann_P , Sorry if you can tell me the case that let you need this other than the ability to change from any model view, I didn’t know this fact before but feel it’s good to stay like this otherwise you share a case made you need that.
AC 27 INT 5003/WIN 11
Explained back in the original post.
https://community.graphisoft.com/t5/Document-Visualize-forum/Create-grid-in-section/m-p/332493/highl...
