2023-03-06 11:23 AM
Hello, Was the issue of zone grouping solved in AC 26 ?
As far as I know it wasn't.
So I suppose millons of architects are waiting for this possibilitiy with AC, when they are like me projecting collective housing bildings.
Now I use zone numbers to collect all rooms of one flat in schedules. But I need a way to write the total area directly and automaticly on the plan wiew.
2023-03-06 11:54 AM - edited 2023-03-06 11:55 AM
No. GS doesn't seem to consider higher level entities such as groups, systems and zones to be something worth developing - you can always use the IFC manager!
2023-03-06 01:17 PM
A solution in this post by Mathias with python and a property
But not automatic we must restart the python script to update
https://community.graphisoft.com/t5/Developer-forum/PYTHON-Sum-area-script/td-p/371704
2023-03-06 02:10 PM
Thanks (merci !)
This should be directly included in next AC !
2023-03-06 06:06 PM
In the German version we have the integrated "Wohnungsstempel" add-on (apartment stamp).
It kinda does what you want. But it is horrible and everybody hates it.
Then there is the great add-on by @BerndSchwarzenbacher.
But I agree that there should be a hierarchical order given in the system and something like this should be working out-of-the-box.
2023-03-14 11:47 PM
ArchiCAD really should just replace the Zone tool with a "Space" tool that allows you to group Spaces together into Zones. This would align it with IFC standards. They could remove a lot of the junk that is in the Zone tool right now as well
2023-03-18 03:17 PM - edited 2023-03-18 03:18 PM
Hi Tinou,
A good workaround for this is to use the selections palette. You can save a selection of zones and give it a name. Then, if you need to reselect the same zones again, you simply click on the saved selection in the palette. You can find it by clicking on Windows > Palettes > Selections.
Cheers!
Jarrod
2023-05-16 12:39 PM
Thank you for all of your comments!
I'm happy to say we took notice and registered a wish under WISH-12777.
I hope it will be implemented soon!
Best regards,
Dani Benjamin
Technical Support Engineer
