2015-11-13 01:07 AM
2015-11-13 01:22 AM
robertf wrote:View in 3D with layer combo etc. as desired, right-click in 3D window and select the "New 3D document from 3D…" option. This basically converts the view to a 3D Internal Engine view, you can then draw over / dimension with normal 2D tools. Save the view to your View Map as normal. View can be updated / redefined if required.
I've just upgraded from 12 to 19 and noticed there are quite a few changes.
First: How do you draw in isometric ie plumbing riser diagrams. In 12 I used the 3D view option and set to 'internal engine'. The new 3d view option doesn't have the 'internal engine' option so I don't get the various guide lines of 15deg 30deg etc.
2015-11-13 07:22 PM
2015-11-14 12:45 AM
2015-11-14 05:25 PM
2015-11-15 02:27 PM
robertf wrote:I am assuming you meant "not" for "now". Go to Work Environment > Shortcut Schemes > Keyboard Shortcuts and see which keyboard shortcut is assigned to "Group". You can change it to Ctrl G there.
Ctrl G is now working for grouping objects as it did in AC12. Does it not work the same in AC19??
2015-11-15 08:18 PM
robertf wrote:Sorry, I misunderstood. You wrote you want to "group elements such as lines, circles etc into one." I thought you meant you wanted to unify them into one element.
Thanks Laszlo,
I'm starting from scratch and building my template document. Ctrl G is now working for grouping objects as it did in AC12. Does it not work the same in AC19??
2015-11-16 06:06 PM
