Wishes
Gutter Object
It would be great if it were possible to add multiple outlets to the gutter outlet for larger commercial schemes. We can add multiple objects for the various downspout connection on the same run but it would be better if it were possible to add additional outlets to a single object.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
We have created an all in one gutter object that includes Gutter, Fascia, Soffit, Flashing, Spandrels, and of course Downpipes (any number and position),
You nominate the number and location of the downpipes which can also include an step/kink in the downpipe where walls of different stories step in or out. Each downpipe can also have a spreader applied to the base where the downpipe is above a lower roof that in empties onto.
The geometry is very flexible and you can even save the settings of each individual component (gutter, fascia, DP etc) into the built in catalogues so that you can apply any of your favorite styles in an instant.
This is the latest video but there are a few older ones also on our YouTube channel in the Gutter Plus playlist.
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
That's brilliant.
Lee Hankins
