Wishes
Headline separator as cut/split marker when placing schedules in layouts
JT1986
I have used in many occasions possibility to split schedules among multiple layouts. This is a great feature but would be even better if user could set a special split marker  that would tell the schedule when it's time to continue to the next layout. Example in schedule where every space (headline) and objects in those spaces (value rows) are listed, it is difficult to split schedule on layout so that each space has its own layout because number of the value rows varies between spaces. Headline separator could operate in this case kind of cut/split marker. It would tell when to split the schedule between layouts regardless of the number of the value rows between headline and headline separator.
DGSketcher
Legend
This would be good for transmittal issue sheets where my drawings are grouped by relevance e.g. general plans, services, finishes etc. Sometimes the length of the page leaves embarrassing "orphans" on a page where they should be grouped together.
Minh Nguyen
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this Wish into our Wish database.
(For future reference, you can refer to it as IDEA-4486)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
