Wishes forum
Hide values in schedule
In Taiwan, the client will not review the details of the schedule, as long as he knows the total result.
Therefore, I hope to add an option to the schedule style panel to be able to hide the value. This is very much needed for Taiwanese users, thanks.
8 REPLIES 8
I don't see the need for this.
You will need to save 2 views of your schedule - one with the hide option on for the client and one with it off for everyone else (who I assume will want the totals).
You can do this now.
Save 2 views - one with totals and one without.
Versions 6.5 to 25
hi, Barry
Thanks for your reply, but I can’t find a button to hide the values.
(Note: I found that the name of the picture is wrong, which may cause your misunderstanding. It has been updated.The picture (style_wish.PNG) I modified with GIMP )
TAI.
No there is no button to hide the values.
I know you are wishing for one, but if there was one, you would need to save two schedules one with the totals on and one with the totals off.
Create two schedules, one that shows totals and one that doesn't.
The totals are controlled in the schedule fields or you may have the SUM button active on some of the fields.
Or maybe I am misunderstanding what you want.
If you want to group exact items rather than listing them separately, there is an option in the schedule settings to 'Merge Uniform Items'.
Versions 6.5 to 25
hi, Barry
Due to busy work, unable to reply in time.
I found a way that might solve my problem.
https://howtousearchicad.com/table/chart/7242/
TAI
vdentello
I'd love a schedule that would show totals only. It's indeed useful for reports.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
Isn't that what the "Merge Uniform Elements" option does?
You still need to know the element you are scheduling and have the total for that element.
i.e. 2400 x 1000 door - total = 6
You wouldn't just want 6?
Versions 6.5 to 25
gdford
As a rule I have found that most folks do not really understand how the schedule works and the power it has to help you do all sorts of things. Having said that - it is time for the schedule to get a major upgrade.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
gdford
In particular it would be amazing if the schedule tab on the toolbar could become a floating window that would stay on top so i could see the schedule while working in a 2d or 3d view.
Gary Ford
Archicad 12-25
(RAM) 128 GB
NVIDIA RTX A2000
