Wishes forum
Hyperlink text option
gdford
I wish i could drag a hyperlink from a browser toolbar into archicad, and instead of it just turning into text, it would also become a functioning hyperlink.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
Win 10 - ASUSTeK Zephyrus M GU502GV - 64 bit
Intel(R) Core(TM) i7-9750H CPU @ 2.60 GHz
16.0 GB ram
4 REPLIES 4
Gerald Hoffman
Great idea, you should make it a Poll Wish.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
Just in case you didn't know, it is a functioning hyperlink once you publish it as a PDF.
It is just not a hyperlink inside of Archicad - not even on the layout page.
So there is no way to test it in Archicad without publishing as a PDF.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
gdford
yes - that is correct - which is great for folks views the drawings via pdf.
Where i was going with this is that the hyperlink should work inside the model to help provide instant access to information that helps a team work on a project.
For example a link visible in each space that that opens a onenote doc with specs for the space.
Gary Ford
Archicad 12-25
16.0 GB ram
Minh Nguyen
Graphisoft Moderator
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this Wish into our Wish database.
(For future reference, you can refer to it as IDEA-4222)
I hope we see this get implemented in the future!
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
