Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Hyperlink text option
gdford
I wish i could drag a hyperlink from a browser toolbar into archicad, and instead of it just turning into text, it would also become a functioning hyperlink.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
8 REPLIES 8
Gerald Hoffman
Great idea, you should make it a Poll Wish.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
Just in case you didn't know, it is a functioning hyperlink once you publish it as a PDF.
It is just not a hyperlink inside of Archicad - not even on the layout page.
So there is no way to test it in Archicad without publishing as a PDF.
gdford
yes - that is correct - which is great for folks views the drawings via pdf.
Where i was going with this is that the hyperlink should work inside the model to help provide instant access to information that helps a team work on a project.
For example a link visible in each space that that opens a onenote doc with specs for the space.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this Wish into our Wish database.
(For future reference, you can refer to it as IDEA-4222)
I hope we see this get implemented in the future!
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
cocoloco
I need this too! What's disappointing is to see you wrote this wish in 2021??? Unfortunately I can't find this "upgrade" yet
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
Jeff Thompson
I would like to change some text into a hyperlink, as I'm typing in my text box, that links to certain layouts in our Layout Books or views in our View Map.
Example:  If I type in text that reads "See detail 7/A8.07".  If I was able to hyperlink the 7/A8.07 to that sheet or view, and someone in a published PDF was to click on the 7/A8.07 text, it would take them directly to that sheet in the set or directly to the view in the set.
I'm thinking this would be great for jurisdictional plan reviewers to review our sets easier, and also contractors and subcontractors that are viewing the PDF set on a tablet or phone.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Desktop, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 26 - Graphisoft Forward
IDEA-4222
Hurry! it is 2024..  building design becomes more and more driven by building regulations published on the internet.
It is very useful to be able to point to regulations on your drawings.
It is almost unbelievable this function is not there already.
Best regards
Andries MIXD
MacBook pro 16 inch. 2,4 GHz 8-Core Intel Core i9, 64 Gb, Archicad 26-27
MSDC
I don't think this is even on the roadmap! It's a pretty basic feature and fundamental for project/company guidance.
Is there any update on implementing the ability to create a functioning hyperlink?
