2008-09-08 05:50 PM
2008-09-09 05:48 AM
Chrisdell wrote:
I was a little hesitant because it seems like so often the packaged tutorials are often based on the 3D part of the program which is something that I'm not very interested in at this point in time. I'm more interested in producing quality construction documents efficiently,
2008-09-09 05:00 PM
Erika wrote:
I think you might be missing a key point of the importance of the 3D model. Your details are started from the model.The accuracy and detail level of your modeling is what will get you your 'quality construction documents' and efficiently.
2008-09-09 05:55 PM
another Moderator
2008-09-13 12:52 AM
ejrolon wrote:But it is compatible with AC9 (yikes!) see comments here...
AFAIK the Start Edition is not compatible with the Regular Edition, the file has limitations like the EDU and it is usually one Regular Version behind, AC11 Start equals a limited AC10.
2008-09-13 01:09 AM
another Moderator
2008-09-28 08:26 PM
2008-09-30 04:35 AM
2008-10-21 05:26 AM
2008-10-22 11:35 AM
Chrisdell wrote:Hi Chrisdell,
A guy who I met through the friend that convinced me to buy AC (did you follow that?) works at a 10 or 11 person firm that uses AC. They switched a little over a year ago. Now I don't know what training they had or what, but today they came into work to find that every seat of AC had been removed and replaced with Autocad Architectural Desktop. The owner of the firm said that hours billed had TRIPLED since they had moved to AC and since those who used it were still not at a comfortable level of efficiency he decided enough was enough.
2008-11-01 04:57 PM
