2021-08-25 05:56 PM
2021-08-26 03:30 AM
2021-08-26 09:23 AM
2021-08-26 02:04 PM
2021-08-27 04:37 AM
Eric wrote:Just holding the SHIFT key while drawing the wall will lock it to predefined angles as set in your Work Environment.
Axis lock
2021-08-29 08:33 PM
Barry wrote:I don't have any problem drawing walls to a grid of using the shift lock as I draw. The problem is when the boss, or anyone who has less experience with Archicad jumps into a project and makes changes. Or worse will make changes like a stretch and then stretch it back by eye. No one knows that it was changed until later in the project when stuff does not line up right or dimension correctly. A quick way to highlight untrue elements would be an enormous help in trouble shooting.
Axis lock
Also the blue snap guides can be used - they don't lock the wall angle, but you will snap to them when the mouse is close.
2021-08-29 11:57 PM
2021-09-03 04:24 AM
Yes, graphic override would be nice. For detecting non-orthogonal elements, this label (if you don't mind using the label tool) comes handy. https://bim6x.com/blog/fixing-untrue-models
Architect | Graphisoft Certified BIM Manager
ArchiCAD 26 & 27 JPN USA & INT | Windows 10
2021-09-13 01:46 PM
Hi All,
Thank you very much for the discussion!
I am happy to say we took notice of this wish and I have added it to our Wish List database (please refer to it as IDEA-4528). Hopefully, our Product Management team will adopt this one in the future. Personally, I think it would be a very useful feature!
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
