2017-07-17 07:25 PM
2017-10-24 06:12 AM
2017-10-29 03:49 AM
2017-10-29 08:28 PM
2017-10-29 11:42 PM
2017-10-29 11:50 PM
2017-10-30 06:51 PM
2017-10-30 08:29 PM
laszlonagy wrote:Select Door, view/select Anchor Point in Info Box,
For example, I place Doors, and in certain cases I want them to be at a certain distance from the Wall corner or a connecting Wall.
Let's say I want it to be 100 mm from the wall corner.
Seeing the Anchor Point of the Door would come useful if the Door is resized to a different Width. If the Anchor Point is on the side of the Door closer to the Wall corner, than resizing the Door will resize it so the Anchor Point position of the Door stays at the same place, still 100 mm from the wall corner.
If Anchor Point is not at the correct position then after resizing the Door will no longer be 100 mm from the wall corner and needs to be moved.
2017-10-30 08:53 PM
2017-10-30 09:08 PM
