WHEN WE SELECT A WALL OR ANY OTHER COMPONENT AND WANT TO EDIT IT IN SECTION THROUGH COMPLEX PROFILE I THINK IT SHOULD BE APPLICABLE TO ALL DESIGN COMPONENTS PLUS WHILE EDITING THERE SHOULD BE COMPLETE 3D ENVIRONMENT LIKE WE CAN NOT ON;Y EDIT SECTION BUT ALSO IN PLAN AND ELEVATION..MAKE IT DONE FELLOWS..I SHALL BE VERY THANKFUL TO YOU....PLUS..INTRODUCE SOME MORE MODELING TOOLS .I DON'T WANT YOU TAKE HELP OF 3D MAX...I LIKE ARCHICAD SO PLZ MAKE IT WORTH USING...GUYS..MAKE SOME EASY ARRANGEMENT'S FOR 2D AND 3D SCRIPTS LIKE WE CAN DRAW ANY THING AND IT BECOMES PARAMETRIC AUTOMATICALLY.MAIN ISSUE IS.COMPLEX PRFILES AND SOLID EXTRUSIONS...THEY ARE NOT THAT COOL AS THEY CAN BE...SO GUYS WHY YOU ALL SO LAZY GO PRODUCE A PERFECT SOFTWARE..i am using this from like past 3 years m an architect..and loving it but if..you can make above suggested change than it would be like perfect.....thanks..alll....hugs
