2019-12-31 12:03 PM
2020-01-21 10:57 AM
2020-02-05 11:10 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-06 08:27 AM
2020-02-11 09:27 AM
Minh Nguyen
GRAPHISOFT
2020-02-11 10:55 AM
2020-02-11 03:59 PM
Minh Nguyen
GRAPHISOFT
2020-02-11 04:16 PM
mnguyen wrote:I haven’t been able to do that, with IfcFooting. Can you show me how, please? I modelled the footing in ArchiCAD, using beams and slab tools, export the IFC mapping them into IfcFooting, import the IFC, and the result was that they were imported into objects.
On the other hand, ARCHICAD provides a solution in cases of files exported from ARCHICAD and imported back to it, with the classification based export and import type mappings in the IFC Translator Settings. So if you export an IFC from ARCHICAD, it is possible to import it back with all the tool types correctly assigned to all elements.
2020-02-14 03:20 PM
Minh Nguyen
GRAPHISOFT
2020-02-14 04:42 PM
