2005-11-08 07:03 PM
2005-11-08 08:53 PM
DavidJVIncent wrote:Amen, brother. (Don't forget to vote for your own poll!)
I think it would be fantastic to be able to merge details from one project into another. In fact, I think archicad users should be able to have a file just with details that can be utilized and imported into any project. If there is any way to actually merge details I would love to know the way. Currently we copy and paste details into files we are working on because most of the projects we work on use all the same details.
Thanks,
David J Vincent
2005-11-08 10:56 PM
2005-11-08 11:31 PM
2005-11-08 11:32 PM
Karl wrote:what in the world did you say that was censored there???
This latter import would then give an easy way to <b>[censored]</b> in a bunch of DWG details as well as details publishes as MODules (or 2DL).
2005-11-09 12:01 AM
2005-11-09 05:09 AM
DavidJVIncent wrote:If you have independent details (e.g. fence, driveway details, etc), you can use them in PlotMaker. The problem here is referencing - which can be partially solved by merging your Independent detail file with the main one, but the referencing has to be done semi-manually ...
All I want to do, that I think would be great is to be able to create a new independent details file called Details.pln. The idea would be to have a file with only details that are used often and can be built upon, then when a project is underway simply import the details from the main details file into the current one. This way a Firm could have an entire database of details and could just reuse details rather than always have to create them. This would in turn give a firm more play time and less work while at the same time increase profits.
2005-11-09 06:14 AM
Ignacio wrote:Well, I was trying to say "s.u.c.k in" ...Karl wrote:I am curious as to what are you thinking of doing to those innocent details.
This latter import would then give an easy way to <b>[censored]</b> in a bunch of DWG details as well as details published as MODules (or 2DL).
2005-11-09 06:25 AM
DavidJVIncent wrote:If you don't mind manually merging each detail, then you have this ability today in MODule files.
2005-11-09 11:26 AM
