Wishes
Improve Settings Management for Element ID Manager
A fellow user has noted a problem with the Element ID Manager settings:
http://archicad-talk.graphisoft.com/viewtopic.php?p=10306#10306
These settings are stored (for Windows people - not sure for Mac) at:
c:\Documents and Settings\USERNAME\Application Data\Graphisoft\EIDM
To share a created setting, this folder needs to be physically copied to another user's settings folder on the same or different machines at present. Unfortunately, copying it will wipe out any settings that already exist for that other user. Not a real solution.
This simple wish is that EIDM settings be managed more flexibly, consistently and intelligently - perhaps using the same approach as that used by the Interactive Scheduler (IS) (see the Settings dialog). With the IS, the default location is a sibling of the folder above ... but one can (a) change the location to a different folder - for example a location on a network drive, or at least one that is more likely to be backed up and (b) import selected settings from a different folder.
Thanks,
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
3 REPLIES 3
Djordje
Ace
I would expand this to (following partly Michelle's wish) to a ... let's call it a snapshot? ... way of being able to save ALL your setting within the current ArchiCAD file AND/OR a separate snapshot file. That would enable CAD management over network(s), unify working environment, ease working at different locations. Maybe by user? Or project? And, to make matters worse, it should be crossplatform (e.g. you have a Mac at home and a PC at work, or vice versa).
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Agree. A better long-term wish ... and with export capabilities then too (IS can only import). Then, something like Attribute Manager can be used to bring in selected settings for all of these other things ... or to create a settings file like the current aat that can be given to someone to selectively import things into their project.
Don't forget to vote, or is the moderator not allowed to? 😉
Thanks,
Karl
Aussie John
Having the setting reside on a computer caught me out badly as i often travel to the Main office ( interstate) and my schedule wasnt there any longer.
Cheers John
[/size]
Learn and get certified!
