Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
In place parameter editing
AC8 introduced the "diamond hotspot" allowing us to edit specific geometrical parameter in plan view.
When hitting these hotspots, a popup window appears to let us type the value desired.
Wouldn't be useful if other parameters such as drop down list or material could be accessed this way ?
Red
I think little things like that can help production times! So I definately agree.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
Geoffrey,
This is a BIG one. I have often wished for this (and can't believe I haven't posted it already).
Besides pop-ups in the drawing window for values lists, how about library parts with editable text fields?
Thanks for bringing this up.
Matthew wrote:
Geoffrey,
Yes ! If the object creator could specify which parameter could be accessible directly from the editing view without having to open the object dialog box, and if it had the choice to let the user edit ANY parameter this would be great.
The next thing would be a single key shortcut to access the values and keyboard navigation between these fields :
switch to another values : TAB or SHIFT TAB
validating a value, with visual return (means the object is changed) : ENTER
completing the edition / quiting the edition : SHIFT+ENTER
You're welcome 😉
