Wishes
Intelligent Linetypes
Paul King
I would love to see complex linetypes with the ability for their individual component parts to interact in thier own right when required:
- To trim neatly against an intersecting angled element (currently must either stop short or run over length). eg just try trimming an insulation line type around a mitred corner using the current tool !!
- To be individually snappable
- To allow components consisting of fills - with different pencolour to fill vs outline vs background
- To allow on screen dynamic spacing/setout of repeating elements on the fly, without necessarily requiring a new definition for each variation
I accept this would make them much more resource hungry, and so this functionality would need to apply to a distinct category of linetype - accessed only when needed
The current alternative is to manually array repeated items - monstrously inefficient when the array also needs the properties of a single dynamically adjustable element, including ability to rubber band, trim, curve etc
In effect you would be creating a new, much faster and much more untuitive method method of copying and grouping repeated elements
In principle, could even consist of 3D components!
What do others think?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
4 REPLIES 4
Here is a good idea. Designers use lines and sketching before we commit to wall types, etc.
I have another wish, similar to "intelligent lines."
Since I use lines to "sketch" and outline buildings I would love it if I could click on a line that I may have placed earlier and be able to read the length of that line.
I often layout a project, but forget my assumptions and dimensions. This means drawing another line, or using the dimension tool to confirm earlier decisions.
How great it would be to just click on a line I may have placed an hour ago and see the length of it.
__archiben
and more?
mate - that's what the element information palette does:
~/archiben
b e n f r o s t
~/archiben wrote:
and more?
~/archiben
how about the info pallet showing me the angle of the line?
You learn something every day. Thank you, again.
