matthew
having just read the post about moving section/elevation markers (
http://archicad-talk.graphisoft.com/viewtopic.php?t=1257&highlight=) i agree that this would be a handy implementation.
i would also like an elevation marker to be able to be replicated along the 'cut' line too. some of our plans are too big to show at 1:100 on an A0 sheet. we end up redrawing the elevation markers so that it shows on each of the layouts that the line runs through.
to answer your question about using the hotspots in doors, etc., see attached screenshot. the door opening angle can be adjusted on plan quite easily, but as you can see, a double swing door is currently coded to swing both leafs at once!
~/archiben
b e n f r o s t
