Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Interior views - unwinding of the walls
Hmooslechner
Interior views - unwinding of the walls - Sorry Graphisoft, but Your solution is a "real missing of the target".
Why don't You use the contours from the roomstamp-tool where all necessary information would be available and built it from there as a real "unwinding - drawing"?
So, there are not only rectangular rooms, even rounded walls could be displayed "ok" with my methode-suggestion.
Dont argue! Just make it so!
Also the existing section-tool should be extended, so that unwinding-drawings are possible with it - then perhaps without a cutting depth..
1 REPLY 1
runxel
Legend
The lack of proper unfolding is a real bummer.
Especially when working in existing conditions, where round or elliptical walls are very common.
(Revit also misses this ability, but one could help with dynamo there. Would be a great chance to gain some advantage, GS!)
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
