Every once in a while the elevation dimensions (in S/E) need to dimension 2 objects that are very close together. Using the standard dimensions, you very likely will get the two dimensions running into each other. So what I wish for is for the elevation-type dimensions to be able to be moved while still maintaining the association original to the original point.
See attached pic for the problem I'm referring to
