Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Keep the dimensions while changing between different kind of windows/doors
Hello, i think it would be nice to be able to keep dimensions of windows while changing among different types, for example between ac21 window to 3-sash sliding.
Eduardo Rolon
If I understand correctly this has been available in AC for the last 15 years. Just use the eye-dropper to pick the settings of the current window, open window settings and navigate to the window you want and BEFORE clicking on it use the syringe to apply the settings.
Read or search for Element Transfer in the Help Center for more info.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
Yes this way works. Never thought i could inject properties in the window settings. Thank you!
